L2900 2wd
martyfair57
martyfair57@yahoo.com
Jan 16, 2015
west monroe la
Hey guys i need some help? My L 2900 has a clutch problem. The clutch works fine if, you hook your toe under the pedal and pull it up, but it will not engage on its on. If you pull it up it does not slip at all, it will will pull tractor front end off the ground if need be. Just cant figure why pedal will not return on its on? Anyone help me with this? Thanks in advance!
6,433
Look for a broken clutch pedal return spring (#040), lube all pivot points, and if none of the above works you will then need to dive into a split.
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to the forum. It sounds like the return spring is off or broken.
