Hey guys i need some help? My L 2900 has a clutch problem. The clutch works fine if, you hook your toe under the pedal and pull it up, but it will not engage on its on. If you pull it up it does not slip at all, it will will pull tractor front end off the ground if need be. Just cant figure why pedal will not return on its on? Anyone help me with this? Thanks in advance!
