L2900 - 1000 Hour Service Items?
Clutch
L2900, RTV500, T2380
Oct 21, 2024
57
17
NY - USA
Hello everyone.
New to the forum, and to Kubota tractors (but not tractors in general)
Recently agreed to buy a L2900 that has close to 1100 hours on it. I am not completely sure of the maintenance history, so once I get it home I figure its time to start hitting up all of the items that should be sorted out on a machine that you dont know anything about. Was hoping some folks here could help correct/amend the list in case I am leaving anything out of it. Also would appreciate any known bits and bobs for this series that I should either evaluate or replace early or keep an eye on. I know this is a bit of an older machine, but I figure that works to my advantage with less complexity, as long as parts are still available.
So here is what I am thinking I need to do:
  • Obtain Owners Manual, Parts Manual, and WSM.
  • Change Engine Oil and Filter (I have a pail or two of 15w-40, figure that's good here? Or is this one of those 10w-30 diesels?)
  • Change Transmission Oil and Filter (Thinking of Delvac Tractor Hydraulic Fluid since I have it. Have a partial bottle of SUTD2 from the RTV, but not sure if the glide shift transmission in the L2900 will like the different fluid)
  • Change Fuel Filter/treat fuel
  • Grease everything up
Anything else Im obviously missing? I think that on this machine the power steering and loader are all off the same pump/sump, so don't need to change out different systems. Any obvious o rings I should buy or seals/gaskets when doing the above maintenance that don't typically come with the filters? What is the consensus on crossing filters here? NAPA equivalent OK, or stick with the OEM? (not to start a debate....)
Thanks in advance!
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
797
697
E.
I would do everything Kubota has on there list for 1,000hrs and less.
Daily Maintenance Check Points:
  • Tire pressure, wear or damage
  • Oil or water leakage from tractor or implement
  • Engine and transmission oil, radiator and recovery tank, coolant and fuel level
  • Damage to tractor body, tightness of all bolts, nuts and pins
  • Implement and accessory blades and belts for wear and damage
  • Parking brake, speed control lever, all safety switches and easy checker functions
  • Abnormal noise or vibrations
  • Daily cleaning – radiator screen and core, panel and hood screens, air cleaner primary element
General Check Points Maintenance Table:
all items for all hours up to 1,000 (see table above)
9,072
Owners manual, Yes
Parts manual NO, the printed manuals are out of date and number have changed.
Go here instead: https://apps.kubotausa.com/illustrated-parts/
WSM (aka service manual), envelope top right
15w 40 is fine as long as it's diesel rated.
Being that it's a GST you need to stay with SUDT2 if you want it to keep shifting properly.
GST's are very picky about fluid
You forgot Air filters
You need to also drain and refill the front axle.
Red the OPM or WSM as most front axles have several drain plugs
And the main sump will have several drain plugs too.
Oil filter you can cross
Would not cross Hydraulic filters, Use OEM.
Vlach7
L47 305DT JD500C
Dec 16, 2021
380
272
Frazier Park Ca
Depending on your dust conditions, it could be every 10hrs on your outer air filter.
Oh yea, forgot the radiator, blow out with a leaf blower or compressed air, just do not damage your fins.
Clutch
Oct 21, 2024
57
17
NY - USA
Thanks everyone. Appreciate the quick replies and assistance. I'll read through the manuals before coming back with too many more questions...hopefully. I have an extended reach blow gun that I can use to get in by the radiator pretty, and thought about getting an air comb also at some point, but should work to get them cleaned out.
For the air filters, looks like the inner is NLA from Kubota? But I see a cross for Wix. Any issues using that? I know its a safety filter, so not sure if its a huge deal.
Also, I need to get the machine hauled. I see the info for it on Tractor Data, but need to get an idea of weight, length, etc. Any idea if what is listed there includes the loader, or just the machine itself?
Clutch
Oct 21, 2024
57
17
NY - USA
Just got my order of parts in. I'm a little disappointed that the OEM hydro filter is made in China, but I guess it is what it is these days.
Going to try and get a bunch of things serviced this weekend. Transmission might have to wait, still need to get to a local dealer to find some SUDT2. Also trying to decide on if it's worth going with a synthetic for the front axle or just get a jug of gear oil at the dealer....
rudder35
MX4800, G1800, Bobcat E26
May 22, 2023
45
56
ac3510!??
Amazon has the cheapest SUDT2 I could find if you include shipping. My dealer is too far.
