L2850 GST HYD fluid change, now NO FEL
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
59
21
Northern Idaho
So I changed the fluid and filters to super udt2 on my L2850. I used supposedly oem filters. Ran it stationary for 10-15 minutes, tractor wants to move when in gear but FEL won’t move up or down, so I can’t pick up the bucket. Do I need to bleed the system somewhere? Worked perfectly before I messed with it.
2,671
no bleeding ............. continue to move the controls. It will get the air out after some time ...... just keep moving the joystick.
7,766
Sounds like you have a suction leak in the system, or you have vapor locked the pump.
Common when the pumps get worn.
I've had the GST / PS pump loose prime never that main hydraulic.
Try lifting and dropping the three point to see if you can get prime.
Selkirk_D
Kubota L2850DT-GST
Dec 5, 2024
59
21
Northern Idaho
Gotta’ hand it to you Wolfman, your insight and experience is invaluable. I cycled the 3-point up/down 2 times, and Viola! FEL working like a champ again. Thanks everyone all for your help!
7,766
Glad to hear you got it going!
