I just picked up a Kubota L275 for cheap and I am in the process of figuring out why the water is in the oil. It runs fine, very smooth actually and look like the motor was replaced. However, if I cant fix this problem I will need to part it out.
First off, when I pour water in the radiator...it drains...directly to the crankcase. you can hear it gurgle and trickle. I am ruling out a head gasket or cracked head/block because these issues usually only seep water. This water pours right in.
I am in the process of pulling the front gear case cover and I hope to find a blown gasket behind it. Whoever worked on it last goobered the water pump gasket and the GC gasket with silicone really heavy. It has been my experience that these gaskets go on dry and silicone only makes them slippery and prone to pushing out.
Any opinions on how the water could just drain the the crankcase?
Next question...do I really have to pull the *&^% front axle off this &*%$# tractor just to remove this &%$# pulley???
Thanks is advance for the input
