I'm a new Kubota owner, having brought home my first one last night. It's a 1985 L275 with turf tires and most everything appears to be working, including the hydraulics.
It has one serious problem which I knew before the purchase and is the reason for being able to buy it so cheaply, and that is the fact that it threw a rod out the side of the block about a year ago. It appears that one of the bolts on the connecting rod cap (crank end) backed itself out, then the other one of course let go, knocking a 2 1/2" to 3" triangular hole in the block on the left side. The bottom edge of the triangle extends between the dip stick and the block bolt immediately in front of it, but fortunately neither hole appears to be damaged.
The good news is that it appears the crank journal also has not been damaged and I THINK the piston and cylinder wall are also ok. The tractor starts and runs surprisingly well and I was able to drive it on and off my trailer when loading and unloading it. It is now in my barn awaiting surgery.
I am currently looking for a used connecting rod for this engine and was wondering where the best salvage yard would be to find one for a reasonable price. Or, does anyone on this list have any used parts? My other question is whether or not I'll HAVE to find a replacement block or can I take this one to a welding shop and have a plate welded over the hole. Either way, I'll have to split the tractor and pull the engine to replace the connecting rod, correct? Any other suggestions?
I'm anxious to get this thing running so that I can be using it around the property, almost as anxious as my two boys, ages 12 and 5! Any advice would be appreciated.
