L2502
crow0021
Ontario
Hi all, new to the forum. :) I'm currently looking at buying an L2502. My question is how many ppl use this for some lawn mowing?? Is it just too heavy for that type of work? I'm planning on using an 60" finish mower with it.
WI_Hedgehog
Apr 24, 2024
600
736
Milwaukee, Wisconsin, U.S.A.
See this thread:
Speed25
L2501(sold) - BX25D
Apr 23, 2024
205
284
NC
My L2501 with loaded R4 tires and an empty loader was NOT friendly to my yard at all. Turf tires would've helped, but if it had rained within the last week, the L left shallow ruts and the tires chunked up grass.
My BX weighs a few hundred pounds more than an L2502 without a loader or loaded tires, and it'll leave light marks in the grass and the R4s will only tear up grass if I spin the tires. With turf tires on, it's generally fine unless I'm making really tight turning circles.
I say all of that to say that if you're running an L2502 with no loader and unloaded turf tires, you'd probably be fine if you're on pretty flat land as that setup is pretty light. I wouldn't try it on sloped land though as the center of gravity would be pretty high.
Dchemphill1
L3901HST, brush hog, L525 loader, rear blade, forks and bail spike
Jun 9, 2016
108
42
Fort Calhoun, NE, USA
If you can get a tractor for tractor work and a zero turn for lawn work. Maybe they will give you a great deal?
crow0021
Ontario
See this thread:
Thanks, good reading
crow0021
Ontario
Thanks for your input
crow0021
Ontario
Not an option for me. I don't want to get into multiple machines. I need a "jack of all trades" machine and I realize it may not be perfect for every task. :)
old and tired
L2800 HST; 2005; R4
My L2800 is the oldest step-sister to that model, been mowing my "lawn" for 20 years with it, 72" FM. My question to you is how pristine is your yard? If the yard was sod and manicured weekly, thick grass with strips, you might not like it as much.
My "yard" was a field and since being cut enough times, looks green enough to be a yard with grass... It's good enough for me!!!
I don't worry about the yard, I don't fertilize it, no weed spraying... it grows fast enough for me without trying to make it DARK green (like my neighbors!!) If the wheels mark it up, by the next time I mow, those scuff marks are gone and it's good enough for me.
Orange man
Kubota L2502 LA526 loader , woods prd6000 mower, Land pride RB 1672
Jul 23, 2014
247
157
WNY
I have been mowing with a L2501 for years, had a l3200 before that, It works great for me. I don't have a golf course like lawn, so maybe that makes a difference, but I think it works well.
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,536
1,999
Western MT
From what I've found a L2501 is about 600 lbs more than an LX that is marketed as a tractor to mow with a midmount mower.
There is a big difference in weight between a L2501/2 with loaded F4 tires and loader compared to the same tractor without loaded tires and without loader. The loader and bucket is over 1000 lbs and loaded tires are around 500 lbs.
A light finish mower would help compared to a heavy one. You could be looking at 2000 lbs difference between finish mower without loader/bucket and without loaded tires.
So, yeah, my L2501 is not friendly to my yard, but I live in dry country and have only been in my yard with loader loaded tires and heavy rear implement. But, using my rotary cutter on one of my nearby thick fields didn't leave any tracks.
GrumpyFarmer
3,749
Good day.
IMO tire selection and how / when machine is used make a bigger difference on the result. To be fair, it’s have a ‘low maintenance’ yard. That means the grass is healthier than most yards and the dandelions feed my bees. I don’t have any concern to drive a truck or tractor across my yard. 😉
I have a B with loaded R4 tires (had a BX with R4s before that)…if using in 4WD it’s going to look like someone slipped with the clipper at the barber shop. Same as f using the turning brakes on a B (I don’t know if L has them or not?) if it wet enough to squish when walking I’d let it dry out before using the tractor on it. If it’s wet and sloped, that’s just playing with fire whether squishy or not.
That being said I tore up more grass with my bucket than I have with the tires. (Operator error as well)
I also have an MX (loaded tires and wheel weights) and use it primarily at our place up north which has a manicured lawn…I drive it on the lawn…same experience as with my B and BX. Ifs it’s wet it leave a a mark. The MX sighs a bit more and so long as not too wet it leaves an immediate mark but springs back up. Only time I have left wetness marks was when I should not have been playing in the yard. If trying to turn real short in 4WD or using the split brakes, it’s not going to work out. YMMM.
BBFarmer
Jul 12, 2024
358
709
Terry, MS
I cut with a L3301 and 72" rear mount for a few years. On r4s she wouldn't hurt the grass unless it had recently rained.
I cut several acres of blueberry lanes and would always take the loader off to just for clearance.
1,834
I apologize for this but just can’t stop myself - you hit a jackpot on unintentional “dirty” statements in that post! 😁 :devilish:
3,398
Your set up will make a difference.
Are you going to take the loader off and on?
I would imagine that without the loader, and if it is equipped with those "turf tires" it would be fine on dry grass.
I will say that my 2501 will leave small indentations if I drive on my grass when dry, and if I turn, it will tear it up a little. However I have my loader and backhoe on 98.789% of the time and I have those R14 tires, so that's also a factor.
EDIT: I forgot to mention, I also have loaded tires
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,431
1,651
Near Lancaster, PA, USA
Everyone's land has its own characteristics. Tractors work great for me. The previous tractor, L3200 w/DIY cab had a 6' Landpride. Current L4240 has a 7-1/2' Caroni. Both with loaded rear tires. Loader and frame always removed for mowing. My little Ford 1210 w/ 5' Caroni and unfilled R1's leaves more marks. I can get on the lower yard within a couple days after flooding. The flooded and mowing pictures were taken on 9/1/21 and 9/4/21.
3,138
I take it you mean an RFM as your mower?
All I can add is that initially I had 1.5 acres and bought a RFM for my B2910, and while it worked well, it did not work well for cutting CLOSE to something like a fence, or cutting around the edge of my small pond, about 80 by 50 feet or so in size. VERY difficult to cut close to something you are cutting around, unless you like mowing backwards...
With a few acres and/or nothing to mow around, an RFM shines...lots to mow around and less property, an MMM was my choice. I ended up buying a BX with MMM and a Brush Hog for my B, and with more property now I am a happy camper. Traded in the RFM and got the brush cutter plus some cash at the time. RFM had very little use and was traded back to the dealer that same year.
