L2502 wont start
Scm
BX23S
Sep 28, 2024
444
415
Missouri
Curious as to why the WSM would show two different #3's
One is just a cover, the other shows an actual lever
11,291
Different versions of the same engine, but that's not what you need to take off.
Pull the side cover with the oil fill port.
You need to align the rack with the slot in the block (yellow) to remove the Injection pump.
Hope you pulled the whole idle assembly out as one peice!
Scm
BX23S
Sep 28, 2024
444
415
Missouri
I'm assuming these are the rack and slot?
I cannot move the injector to line them up because of the studs on top and the rack wont move either when I push it. I didn't push too hard, don't want to break more. Should it move easily?
11,291
Yes the injector rack should move very easily.
On some models you need to remove the 2 springs off of the linkage to get the govenor linkage out of the way.
It does not appear to be your case.
If the rack is not moving easily, you're in some serious muck (that's putting it very PG).
That indicates major debris has gotten into the pump and probably has done damage.
It's going to take a professional rebuild to fix it.
The only way to get the pump out is to force the rack to move to the slot.
Scm
BX23S
Sep 28, 2024
444
415
Missouri
I guess the (only) good news is I'm on the right path.
Got it out.
Thank you for all the assistance!
11,291
Word of warning:
If you disassemble it you will not be able to set the timing curve on the individual injectors on reassembly.
In doing so, will it run, yes, will it run right NO.
11,291
Also note:
If that much junk got into the injection pump, the chances that all the injectors are contaminated / damaged / plugged it highly likely too.
Scm
BX23S
Sep 28, 2024
444
415
Missouri
Word of warning:
I already called the dealer and they are going to work on it. I've done enough damage already.
Also note:
You are full of good news. 😂 :LOL: :ROFLMAO:
Should I take those out to be cleaned/replaced:sick: anyways?
11,291
You do know a dealer will either send the pump out to have it rebuilt or put a new pump in it.
Same goes with the injectors, they will send them out for rebuild or replace them.
You can send the pump and injectors to be rebuilt for much cheaper.
If you don't have someone local that does fuel injection rebuild work, you can send it to: https://oregonfuelinjection.com/
11,291
Oh and parts from a dealer are going to floor you!
Dealer Injection pump: 1j871-51010
$1800
Dealer Injectors : 1J829-53000
$250 each
Aftermarket Injection pump:
$850
No aftermarket injectors avalible
Rebuild injection pump will be close to aftermarket price
I know I'm a ray of sunshine! :confused: :p;)
Scm
BX23S
Sep 28, 2024
444
415
Missouri
It's running again. I had to take the injection pump apart twice for a good cleaning. It was pretty nasty.
Scm
BX23S
Sep 28, 2024
444
415
Missouri
Yea me either. How many hours are on it? You mentioned it wasn’t your machine. Did they try to run it on water?
About 250 hours on it.
It did sit for 5ish months before I started using it.
I should of drained the fuel before using it but didn't think diesel would go bad that fast.
Apparently they started adding water (BIOdiesel) to diesel just like gas (ethanol).
Scm
BX23S
Sep 28, 2024
444
415
Missouri
So after getting most of it put back together. I decided to try starting again. No luck.
I remember after last time I took the pump out I had to move the rack with a screwdriver again.
So I took off the oil filler cover and moved the rack. Started right up.
Shut it off and tried restarting it, no luck.
Moved the rack, started right up.
For some reason the rack is sticking
11,291
It's most likely sticking from the rust in the pump.
That's one nasty looking pump.
11,291
It's pushed back by the stop solenoid.
