L2501HST cant remove assembly nozzle
juanm625
Kubota L2501 HST
Sep 25, 2026
California
hi everyone, im attempting to remove these parts on my kubota L2501 tractor because it was struggling to start and then stopped starting up completely.
The part is called “assembly nozzle holder”, part number 1G852-53002. am i supposed to unscrew it or should it be able to be pulled out? yanking on it has done nothing so far. ive attached pictures showing what i am trying to remove and the part i have to replace them IMG_7081.jpeg IMG_7083.jpeg IMG_7084.jpeg IMG_7079.jpeg
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
709
328
Herald Calif.
Why are you trying to remove them? What troubleshooting have you done? Is highly unlikely that you have bad injectors causing it not to start. The most common problem on these machines is the small lift pump. Do you have fuel to the injection pump?
