L2500 Over Heating
10,362
Re: Over Heating
Second what Bulldog said,
First pull the radiator net clean it and then, back flush the outside fins of the radiator with a garden hose, from the fan side.
jrepp44
B2650
May 11, 2015
NE Louisiana
What implement(s) are you using? I recently replaced the medium lift blades on my rear finish mower with high lift blades and my B2650 started running hotter than usual - changed back to medium lift blades and all is Ok. Maybe you don't have enough PTO HP for the implement you are using?
mickeyd
Mar 21, 2014
1,192
Guin, AL
Welcome to OTT W. It seems that all L series tractors have that problem as it doesn't take much to make them overheat.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I fixed my heat problem. Mine will run a little hotter than normal when the radiator get full but I haven't had them get hot enough to make me quit working since they were new.
Shadow
190
Somewhere
I would use compressed air if you can clean it out, as it won't attract more dirt. If you can't get the radiator completely clean, cleaning it with water just makes it worse, then you make mud.
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
Compressed air is a little too strong it can bend the fins. Canned air works, as does a shop vac set to blow instead of suck.
You also should not have much actual dirt in your radiator on an L series. It's way back in there and you should be cleaning it like this REGULARLY.
There is almost no heat overhead available on an L series so you don't have much leeway between normal operations and an overheat condition. That gauge can go from normal temp to max in under a minute if you're working the engine, especially while mowing.
I religiously blow out the radiator every morning before operations and before I fire it up again after lunch if I'm mowing. This has kept my L series down in normal temps the entire time I've used it since my near overheat.
When I wash the tractor before I put it into storage, I run water through the radiator to keep it nice and clean. No dirt gathers in my radiator, it's vile evil stuff that I keep outta there! No mud allowed! LOL! :D
