L2500 Brakes seized
29durant
ottawa ontario canada
Hi everyone I am new to the forum and have finally figured how to post:eek: My 1999 has brake problems the levers for the Brakes on the differential will not move ? The brakes are locked on any ideas?
Stumpy
L175
Dec 1, 2011
848
NE Ohio
Need some more information. Are both pedals stuck? When did they seize up? Was the parking brake set when they locked? Peddle feel strange anytime before it seized?
Could be the parking brake. That's easy to check. It's possible the pedal is stuck on it's shaft. Undo the linkage and make sure the pedal is moving freely to check that. It's also possible something internal in the mechanism is broken or is binding. If all signs point here there isn't much to do but open it up and inspect.
gurn
Kubota L175
Apr 15, 2011
239
Nashville,Tn
Try a rubber or brass hammer, I used o dead-blow on mine when I got it and they freed up enough for me to remove the drums.
