L245DT Squeek/Chirp Sound
Rustypig
245DT w/ L1200 FEL
Oct 7, 2025
N. Idaho
Started hearing this loud squeek sound, almost like a high pitched chirp that sounds like it's coming from the rear of the tractor. My kid was operating it and I thought maybe it was the 3 point links being tight and moving back and forth on uneven terrain etc., but later when I got on it I quickly discovered it's in conjunction with the drive train turning. If I push in the clutch it quits. It's very high pitched and sounds like it's coming from the rear to me but it's really hard to tell, and I'm half deaf anyway. Anyone ever experienced and an issue like this? I'm kind of at a loss as to where to begin. Oh, and it's not a steady continuous sound, it's like a squeek, quiet, squeek, quiet, squeek quiet is about the only way i know to describe it.
Fedup
374
147
Winchester
You might begin with the drive shaft shield. The shield tubing in contact with the rotating shaft has been known to cause strange squeaks and squeals.
3,149
I think you are thinking of the shaft to the front wheel drive. I am not sure if the driveshaft rotates if 4WD is not on.
But it sure seems like it could cause the noise so should be investigated.
The OP may have a problem with the rear brakes or low oil level in the transmission/rear end. There should be a plug on the side of the transmission case to verify the oil level.
Interestingly a couple of months ago, my L185F (2WD) started making a high pitched squeak after sitting for a few weeks. I think it was the front end pivot point needed to be greased.
11,239
How about instead of your wonderful typed interpretation of the sound, that we step into the modern age and take a video, with audio, post it on Youtube or any other hosting or sharing site and give us a link to see and hear what's actualy going on with it. ;)
Rustypig
245DT w/ L1200 FEL
Oct 7, 2025
N. Idaho
Got it sorted out. I'm an idiot and should have known right away after my kid asked which handle was 4wd and which was high/low range, but it was a couple hours later when i jumped on it. He'd left the 4wd lever 1/2 engaged. So all is well now and my wallet feels fatter than compared to what I thought I was in for on this one.
whitetiger
Nov 20, 2011
3,778
2,183
Kansas City, KS
Wondering what key the pitch of the "squeek" was in? :whistle:
7,709
You guys wondering about description of sounds is humorous.
Last week my wife was taking her car to the dealer for an oil change (it's a 2025 with two years of service included) and she says it has a rattle that is annoying and wants it fixed. I suggested she remove ALL items she might have put in the car and see if the rattle is gone. Nope still there.
So as we're driving to the dealer I tell her don't be disappointed if the noise is not resolved. They are not going to tear the dash apart to find it. I suggested you need to describe to them what and where you hear the noise. She has about 6K miles on it and she says it sounds like it's on the passengers side dash. Her passengers describe the sound as coming from the drivers side dash. We finally come up with the description of it sounds like some loose change in the bottom of a ceramic coffee cup, moving when hitting a bump!
After service and a road test the tech comes in, hands her a finger nail clipper, ink pen and file from the passenger door pocket. A phillips screwdriver in the driver's door pocket. He then said the rattle was her garage door opened which she had laying in the compartment intended for glasses ( I think). We drove home testing the theory, put the remote in there for a while then remove it. Yep, that's the problem!! Hard plastic bouncing on hard plastic.
Sometimes we create some dandy problems.
