T Tweeter New member Equipment L245DT Feb 19, 2024 2 0 1 cincinnati Yesterday at 7:14 AM #1 What oil is recommended for the transmission/hydraulics? How often do you change it? do I need to drain all the old oil out before putting in the new?
85Hokie Moderator Staff member Lifetime Member Equipment BX-25D ,PTB. Under Armor, '90&'92-B7100HST's, '06 BX1850 FEL Jul 13, 2013 11,137 3,077 113 Bedford - VA Yesterday at 7:29 AM #2 Standard UDT would be fine for that geared tractor. You need 2 five gallon buckets - 6 gallon min needed, more if you have FEL If new to you, may want to start fresh and drain old oil. Changing the elongated oil screen would be prudent too. Cost $22 I would change every 200-400 hours Reactions: 1 user
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 7,978 3,126 113 Austin, Texas Yesterday at 4:57 PM #3 I use Traveler UTTF which is supposed to be similar to UDT but less expensive. You can use that in the front axle or use 80/90 gear oil or something similar to that. Reactions: 1 user
