My L245DT has a leak in the front axle where the upper and lower cases slide/pivot.
Is this normally a seal replacement, or indicative of wear in bearings?
The lower gearcase is full of fluid even though it's leaking. Is it right to assume the gear oil from the axle tube leaks through the bearings and keeps the lower case full?
