T takattack New member Equipment L2402DT-M Mar 31, 2009 30 0 0 Sparti Greece May 18, 2009 #1 hello again ... i am trying to find where the steering gear boxand the steering gear case located on my tractor.... any help?
T takattack New member Equipment L2402DT-M Mar 31, 2009 30 0 0 Sparti Greece May 28, 2009 #2 well.... i thought tha was somewhere more easy to check the oils in there....
T takattack New member Equipment L2402DT-M Mar 31, 2009 30 0 0 Sparti Greece Oct 28, 2010 #3 still looking for that thing.... is there any possibility not to have one?
DsBota New member Equipment B8200, G1800 Apr 13, 2010 281 0 0 Milton, Ontario, Canada Oct 28, 2010 #4 Mine is hard to see. It's underneath the fuel tank.
DsBota New member Equipment B8200, G1800 Apr 13, 2010 281 0 0 Milton, Ontario, Canada Oct 28, 2010 #5 Near the clutch pedal is a shaft (called the drag link) connecting the front axel to the steering box. When you turn the steering wheel you should see that shaft move. Hope that helps.
