L2350DT Steering Wheel Removal
Flintknapper
L2350DT
May 3, 2022
1,893
2,379
Deep East Texas
Needing to replace some seals in my steering column (oil coming up through top) but am having trouble removing the steering wheel. I assume the steering shaft is splined, but can't tell if it is tapered or not.
I have tried penetrating oil, lightly using a pickle fork underneath the steering wheel base and also a two jaw puller to no effect.
Anyone done this and can advise. Thank you in advance.
rudder35
MX4800, G1800, Bobcat E26
May 22, 2023
37
ac3510!??
I just pulled one off a B7800 with a 3 jaw puller. Tighten the puller up and then hit it with a big hammer. Might take a few tighten and hits. Shaft ws splined.
Flintknapper
L2350DT
May 3, 2022
1,893
2,379
Deep East Texas
Finally got it off using a bearing splitter underneath the base of the steering wheel and a puller. It was on there TIGHT and made a loud 'pop' when it finally gave in. Was easy to remove after that.
Hoserman
Aug 1, 2022
61
71
Grayling, MI.
Wasit splined or just a Morse taper? If splined, I would put a VERY light coating of never seize grease.
Flintknapper
L2350DT
May 3, 2022
1,893
2,379
Deep East Texas
Yes, Sir....splined (no taper). Will be using some antiseize going back on.
Hopefully not have to remove it again for another 28 years (won't be here for that anyway).
Hoserman
Aug 1, 2022
61
71
Grayling, MI.
Never seize is very versatile. One tiny little speck goes a long way. You put that speck under the handle of someone's Kennedy tool box and by the end of the day they got that stuff all over them. It's one of those, Hey Mack, you pickin yer nose again.😜😄
