L225DT, L2050DT and L2550DT; Are parts interchangable?
daniel.ray77
1976 Kubota L225DT
Nov 16, 2009
141
Salt Lake City, Utah
Does anyone know if the Front Differential Carrier, spider gears and ring & pinion are interchangable between the L225DT and either the L2050DT or L2550DT?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,140
139
Hardisty, Alberta
No they are not, a completely different front axle on the L2050dt and L2550dt than the L225dt. The L2050dt and the L2250dt are the same though.
I looked to see if the L225dt parts fit any other domestic tractor and they do not. Sorry!
Ed
eserv
May 27, 2009
2,140
139
Hardisty, Alberta
Some one else will have to help out here. The L2000dt is Gray market and I don't have any information on them! Sorry!
Ed
eserv
May 27, 2009
2,140
139
Hardisty, Alberta
Excellent! Good to know, there is a guy near here has one. He hasn't been in for parts yet but if he does we can help him.
Ed
daniel.ray77
1976 Kubota L225DT
Nov 16, 2009
141
Sorry Vic, im not sure if your last response was intended for me but i don' need any part numbers for my tractor. The place that sourced the replacement front diff for me somehow was able to verify that my L225DT and the L2000DT matched up. You wouldn't happen to know about how many models of the L225DT were originally sold here in the U.S. would ya?
daniel.ray77
1976 Kubota L225DT
Nov 16, 2009
141
So i have just completed installing a differential from a L2000DT from Zen Noh to a Kubota L225DT and it WORKS!!! Took all of about 2 hours to install the new gear set and make ajustments with shims but it WORKS!!! My tractor is once again 4WD. What a difference it makes having 4wd. The thing climbs over anything now especially with a front end loader attached.
factorten
L2000DT
Apr 22, 2012
Kobble Creek Australia
I am chasing a new left diff housing for an L2000DT - I need the housing, and all internal gears as well as the left axle and universal joint that sits behind the outer housing - does anyone have any idea where I can source one of these from?
daniel.ray77
1976 Kubota L225DT
Nov 16, 2009
141
Call Southern Global Tractor and ask for Anne. 8667425748. Last time i spoke with her (2 years ago), she had an L2000DT with all the parts you mentioned. Good luck
