L225....Steering wheel just spins...
project_x
69
Ottawa
So I clearly have a steering problem :(
Before I get into it this week if the steering wheel just spins....is it the likely cause a broke worm gear or shaft?
or are there other culprits?
Pau7220
Aug 1, 2017
785
277
Scranton, PA
Could be either or both. Good news is that there is plenty of aftermarket parts and complete units available at a reasonable cost through eBay and google. When your done, make sure you have a way to keep water from running down the steering column into the box which is the main cause of failure.
avvidclif
BX2230 L285
May 12, 2020
23
Mabank, Tx
Please find me one for an L285. Non-existent. If you consider $400 and up reasonable I guess ebay is a place to get one for an L225.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,173
965
Williamstown Ontario Canada
Recently I looked up some parts costs for the owner of a B8200 with manual steering.
When I told him the cost of the complete box (according to Messicks) which was around $800 he said all he wanted to do was rebuild it and all he needed was the ball nut and a few bearings and seals. The cost of the ball nut was more than the cost of the complete box.
The trouble with trying to repair stuff on these L tractors is that there are no high quality workshop manuals nor are the parts illustrations very good quality.
Buying a complete assembly helps those who do not do these boxes on a regular basis.
Your loss of steering is likely the rusting out of the small tubes on the outside of the ball nut.
The photo is not of a L225 but typical.
This short video will show you the concept of recirculating ball steering.
https://www.youtube.com/watch?v=OeokGSdVTAg
https://www.youtube.com/watch?v=qD00DIGVhtk
Dave
Pau7220
Aug 1, 2017
785
277
Scranton, PA
please find me one for an L285. Non-existent. If you consider $400 and up reasonable I guess ebay is a place to get one for an L225.
I do.
As a comparison, mine is $2744.68. Paid $300.00 for a salvage housing from a burned tractor to repair my original box... plus all the seals, bearings, and snap rings. I guess that means you have the same box as I do. They're actually very repairable. And I do have a spare housing.
