L2050 No Fuel Line Valve
Napa Estate
L2050
Apr 22, 2011
Napa, CA
Hello out there, I have an L2050 4wd. When under load and the motor heats up the tractor bogs down and stops. I just exchanged the air filter and it still bogs down. I will work on the fuel filter when the motor cools down. Question, can I put a shut off vavle on the hose from the fuel tank to the filter. Kubota forgot this when I bought the unit back in 1990. I hate draining the tank every time I need to change the filter. By the way, am I on the right track to fixing my problem?
eserv
BX24, A1000 Kubota Generator
May 27, 2009
2,183
164
Hardisty, Alberta
Just clamp off the line before the fuel filter with a fuel-line clamp or small vice-grip. either that or be real quick! Many Kubota's are "missing" a fuel shutoff!
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
You can pinch it off or you can put an inline fuel shutoff in it, Personally I prefer to have a shutoff .Just make sure the shutoff is compatable with diesel fuel.
Napa Estate
L2050
Apr 22, 2011
Napa, CA
Thanks I will try pinching it off but the hose is rather thick. I will also have some different size nails to plug the hose end, and have a bucket ready if all else fails. Unfortunately I probably have about 6 gallons of fuel in the tank. (6 x $4.50 per gallon) Kubota screwed up on this, what were they thinking? By the way, do you think this will help my problem of bogging down?
