I have a l185 that i pick from a freind of my freind. Owner said that went to use it on day and it would not start. Not sure he is tell the truth. It wont start. appear to have good compression. I never checked it with compression tester yet. when I got it , no water in radiator. I checked dip stick but did not see any sign of milky substance. I don't have a way to pressurize water system. It was not get fuel so I replace fuel and fuel filter. Tried bleeding fuel system several times with no luck. Had injector and pump ckecked and rebuilt a a local desiel shop It appears to be getting fuel now.
After putting pump back on, I was going replacing upper radiator hose.
While the hose was off, I tried to start the engine I noticed white smoke
come out upper radiator hose. Does this mean I have a blown head gasket?
Also if so will this cause tractor not to start at all? I have a full charged battery and decompression level appears working. I realized for a desiel
to run you need fuel, air and compression? is my instinct correct?Any Help would be great
