L185 rear brakes
DaTow'd
what ever it takes to get the job done
Aug 13, 2013
236
224
Bella Coma BC Canada
Plowing our drive way today the right brake seems to be sticking it makes noise then breaks free.
I jacked the rear up and in neutral I can't spin the tire by hand.
Are the brakes inside the rear reduction gear box. Are they riding in gear lube?
thanks in advance
Best Wishes for the New Year
Hank
3,082
Yes they are internal wet brakes and a disk style (not drum).
11,025
They are before the reduction unit.
Check the linkage.
It's very uncommon for wet brakes to "stick".
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
706
327
Herald Calif.
This is a very common problem with these older machines. The brake actuator shaft that goes to the housing has an o-ring on it about a quarter inch in. The area outside of that o ring gets Rusty and the brakes start hanging up. Spray PB blaster behind the lever that is attached to the rod that goes through the housing. Work the brakes when you do this. It may take a week but the PB blaster will soak in and generally free them up. Good luck
3,082
By the way a true L185 is NOT a gray market tractor!
