Even with thermosiphon, it doesent use a thermostat? Ok. I didnt know that. And im sure system wont work properly with rad cap off.
100% correct.the two wires you mention must be a lead and a return wire, heavy- heavy gauge wire...cannot run a little 18 gauge wire there I am sure as you know....
ALL the current that runs from the alternator, MUST run through the ammeter, cannot be in parallel.......must be in series!
250F with what implement? Gear, RPM. because its possible that you are in that hot zone because you use the wrong gear and the small kubota cant handle the heat.Managed to get 5 dials installed including an electric, and mechanical temperature sensor gauge. Still getting to 250 plus degrees Fahrenheit too often. Both dials get buried on the high side. Going to play with the coolant ratios, run more water and less coolant.
Yep, 5' is pushin it for a L 185, IMHOThanks very much for the prompt reply.
Will push 250F using a 5 foot finishing mower.
1st gear on the PTO and 1st gear drive high.
Perhaps 5 footer is a bit too big?
I've adjusted my tiller to the shallowest setting and can run in 3rd low drive and 1st on the PTO. This keeps me in around 230F which fine with me.
its not l185, its l1801 with 18hp at the pto. 5' its just at its limit i think. maybe some one knows better.Yep, 5' is pushin it for a L 185, IMHO
personaly i think that you have to much antifreeze and thats why you are in the upper hot zone, near the overheating and near, hearing the sound of steam,
with the proper radiator cup you will boil at the 260f.
dont try this.
i hope its not tap water or how they call it in your country,I was able to replace 2 liters of mixed coolant with 2 liters of water.
Forgot to check the strength of the new ratio.
Idle temp has decreased from 180F to 160F.
Wasn't able to run the tiller because the yard is VERY wet.
Good start though!
sure I will take some this weekend thats still an easy thing to do since I havent put the side panels back on yetSteve, do you have any pictures of how/where you installed/mounted the gauges (both ends)? Thanks.
