L1802DT Tie Rod bent?
sgec
L1802DT
Aug 13, 2023
14
Oregon
Is the tie rod for an L1802DT supposed to have a bend in it? I'm guessing it should be straight. Any harm in continuing to use this one (assuming I can get the alignment right)?
sgec
L1802DT
Aug 13, 2023
14
Oregon
Thanks. I will do that. But first I wanted to be certain that it should be straight. Its difficult to find info on the original part number 38380-4404-1.
11,142
Does this tie rod go from wheel to wheel or from pitman arm to wheel?
11,142
Since you have the parts manual for it, can you give me part numbers for #17, 21, 24, 25, 26
I might be able to match that up to other tractor models.
sgec
L1802DT
Aug 13, 2023
14
Oregon
Translated from Japanese:
17 38440-4487-0 Tie Rod End Right Comp
21 38440-4488-0 Tie Rod End Left Comp
24 02174-50160 Nut
25 32240-1228-0 Nut
26 38380-4404-1 Tie Rod
11,142
OK, yes it's supposed to be straight.
Now is it going to hurt being bent, nope, just throws the alinement off just a little bit.
sgec
L1802DT
Aug 13, 2023
14
Oregon
Thank you so much! I'm assuming with the slight bend I should still be able to align it.
