L1801 oil filter number
5,235
1,017
Looking for the part number of the oil filter for a L1801
You will get more info in the Grey section of this forum regarding filters
Your tractor does not have a USA equivalent.
An educated guess leads me to the following: No guarantees!!!!!
If you go to a USA Kubota dealer do NOT give them your model number as they cannot/will not provide service to Grey market tractors
mattwithcats
777
66
Any numbers on the existing oil filter?
Assuming it is an HH164-32430, you can use a Wix 51515 / Fram PH8a (or equivalent) instead, easier to find...
Wix 51773 is even larger...
mattwithcats
777
66
3614 is the little brother to the Ph8a...
3614 and 3600 are same base, the 3600 is an inch and a half longer
Ph16 and Ph8a are same base, the 8a is two inches longer...
51773 is two inches longer than the 8a...
All use 3/4-16 thread...
Ph8a / Wix 51515 should be the correct filter...
