L175 lift cylinder piston o ring
RootedRural
Kubota L175, Caroni TC590 finish mower, bush hog, and box blade.
Aug 11, 2026
Missouri
I recently bought an L175. It has some hydraulic issues where it'll go up (with higher throttle) but then slowly leak down. I pulled the cylinder cover and found the main lift piston was completely seized in the bore with old hardened oil and rust.
I finally got the piston out, cleaned the cylinder bore with EvapoRust down to bare metal, and installed a new O ring (K7561-54370) and white backup ring(32200-37380). White ring first towards the open side then the o ring on top of that. Re lubed everything but it was a tight fit going back in, so I gave it a few light taps with a mallet to get it sunk in.
I put it all back together, and it worked great for about a minute. Then it started leaking down again, I pulled the piston back out and found the brand new o ring and back up ring were broken. Thoughts?
7,378
I would say you pinched or tore one or both during instsllation. Install two new ones.
11,311
Hone the cylinder or replace the liner.
And just to be clear the Orientation is, o-ring (30) is to the outside of the flat ring (31).
RootedRural
Aug 11, 2026
Missouri
Just to follow up, rehoned and put new rings on. So far so good, thanks!(y)
