L175 Hydraulic Leak
Carolina_Cubota
L175
Dec 19, 2023
Charlotte, NC
Hello everyone, new member and tractor owner. I recently purchased a L175 tractor and everything seems to be working fine but i have noticed a small leak from the adjuster knob for the hydraulics under the seat. I would like to get it fixed before it turns into a bigger issue. Im assuming there is some type of o-ring that needs to be replaced but i haven't found any info on getting to it. Thanks for any help, attached are photos of the adjuster
2,615
Why are all those bolts missing around the perimeter? You in the process of removal?
Look at this diagram - there are several places that might need attention
Carolina_Cubota
L175
Dec 19, 2023
Charlotte, NC
7,294
#19 is a cir clip remove it then unthread the adjuster.
Carolina_Cubota
L175
Dec 19, 2023
Charlotte, NC
Thanks for the help, getting the snap ring out was a PITA but straight forward from there. I attached a few photos of the threaded part assembly incase anyone in the future has the same issue and would like a reference.
2,615
You plan on replacing that O ring ? Hard to see shape of clearly in the picture - but replace it and see if that stops the leak.
