3 Point goes down smooth, stays up once its up but is very slow and sometimes "notchy" going up.
I removed pump first, checked it out inside and cleaned it up. had some wear on bronze bushings but nothing obviously major. reinstalled no change.
next I ordered pressure gauge.
while waiting for gauge I removed hydro control valve cover and cylinder/piston. cylinder is pitted and piston scuffed but nothing crazy. ball honed cylinder and polished piston. reinstalled no change.
got gauge and adapter to fit port, got 500 psi max
so question is should I order a new pump or take the whole lift cylinder and cover off to check out control valve? Sound like pump or possible that control valve has issues?
Anyone have parts layout for this tractor? one weird item i'm also needing to source is driveshaft ujoints and rear end of it's yoke splines are all rusted away.
