Hello,
Attempting to diagnose my steering sloppiness and popping. I've got the steering wheel off (never underestimate a block of wood and a hammer!) but now I've come to trying to get the dash and fuel tank off.
Is the easiest way to just remove the whole thing? A couple of things:
1. I presume I'll have to bleed to fuel system after this? Unless perhaps this thing here is a fuel shutoff? The screw above all the japanese writing (the picture is rotated on its left side for some reason, left is up!) Also what's the little gold valve below it? If i can shut off the fuel, i can go ahead and change the fuel filter and replace steering without bleeding?
2. Is the best way to remove the 2 bolts that attach at the back middle of the tank, and then two bolts on the each side of the middle of the tank? They look like a real pain to get to!
3. It looks like i'll need to remove the throttle control. Looks like one rusty cotter pin, remove bolt and I'll be good.
4. Last looks like I'll have to disconnect the hour meter, and what I presume is a choke (although I can't actually move the choke control) - not even sure it's a choke, looks like maybe some kind of idle control or something. Also there is a fuel line that runs into the top of the engine block from the fuel tank, what is this? just some pressure relief so some air gets in the tank to allow it to flow? Seems safe to remove for now
Thanks for any pointers!
- Mike
- Mike
