I have a L1200 loader on my L245DT that had some really nasty rotted hoses. I was clearing snow this spring and one for the loader bucket tilt finally sprung a leak. I parked the tractor for a couple months, and recently replaced all 7 hoses between the controls and pump, as well as the bad one on the bucket (the rest on the bucket looked OK). I made sure to labeled them all and took pictures, everything is back in the same place. Then I topped off fluid, cycled the hydraulics for several minutes to try and get any air out, and made sure fluid levels are still good.
Now that it's back together, the loader is really weak. The bucket arm only goes up about half way, and the bucket tilt barely does anything but clunk a little. I can convince the bucket arm and/or bucket tilt to move if I add slight pressure to the other lever, (in addition to fully opening the lever for the operation I'm trying to use). But even still, operating like that, it's very weak, and won't pick up a bucket more than half full of wood chips. Before this all started it was strong enough to lift the tractor. 3pt hitch hydraulics are still very strong, and PTO is working fine.
Any thing else I should try?
Some pictures of how it's set up...
Controls:
Pump:
Bucket:
Controls:
Pump:
Bucket:
