Be apprised of something. Unless the backhoe has a subframe that will fit your tractor, I'd advise against getting it. 3 point mounted backhoes can put a tremendous strain on the rear case, especially the top link casting if the hoe is horsed around at all or if you move the tractor around using the hoe, or if you loft the rear wheels off the ground with the stabilizers. You need a dedicated subframe to remove the associated stresses.
I'm not saying you will break the rear housing but you can. I know someone who did just that with a Woods Hoe on a 5030 Grand L and it cost $7000.00 to repair. A subframe removes the stress on the case and transfers it to the steel tractor frame. it's really a must have thing for a hoe on a tractor unless it's a dedicated unit.
