L 4350
jvd620
L 4350
Jun 6, 2014
graysville tn
just purchased a 4350 which i believe is gray. It has 16 forward speeds and i downloaded a manual and none of the pictures of the controls match my tractor. also i have been looking for days for a hydraulic filter which is mounted by the three point hitch and 3 different Kubota dealers cannot come up with it. HELP
7,199
Welcome to ott:) you can try your local auto parts store. Just give them the number on the filter. If they can't match the number, you can always take them the filter and have them match it up. ;)
7,761
L4350 is not a gray tractor.
You say that your tractor doesn't match the manual you got, how far off is it?
I find only find one hydraulic filter, it's located on the right side in front of the axle.
I'm wondering if the filter and controls are aftermarket?
Maybe a picture or two of the filter and connection point and maybe a picture of the tractor. ;)
jvd620
L 4350
Jun 6, 2014
graysville tn
its not close to any of the diagrams. if i knew how to post a picture on here i would. 4 speed PTO lever is directly under the steering column and to the left of the seat are gears 1 thru 4 and on the steering column is another lever 1 thru 4. the second filter just above the PTO is cast in the tractor. could not be aftermarket. thanks for any help
FTG-05
L4330 w/FEL, RTV-XG850 and ZD326S
Jul 21, 2013
286
121
TN
If it's not close to the diagrams is it possible you have the wrong manual or are looking at a different tractor in the manual you have?
My workshop manual has at least 4 or five different tractors (L3130, L4130, L4330, etc.). Also since you say the filter is near the 3PH area, it sounds like you have something that aftermarket.
Surely you can find someone that can post a pic of your tractor and the hydraulic filter area. What is the filter #?
Good luck!
List of gray market tractors: http://www.kubota.com/priorproduct/GrayMarketList.aspx
List of filters for L4350: http://www.messicks.com/Wiki/Kubota/L4350.aspx
7,761
To post pictures click on the paper clip on the top of post.
Browse to where you have them saved and upload them.
It's sounds like you don't have a L4350, with a 4 speed PTO it sounds like a foreign model, read the complete Serial # off the side of the transmission, that might give us some insight.
