I just got my tractor and it was rode hard and put away wet. 3 point hitch has never lifted since I owned it and the previous owner added hydraulic lines to run a log splitter. I have flushed and changed all trans, rear axle and hydraulic fluid. Also the hydraulic pump and screen filter were replaced. Checked the pressure relief valve and shimmed it correctly, it was not stuck though. I still have no lift to 3 point no matter the position of the knob under seat is
Fluid and filter were both filthy and fluid had a very fine, white particulate matter that would settle to the bottom of the drain pan. Doesn't seem to be any resistance to the lift arms if I physically lift them. Anyone have any ideas where I should go next? Thanks Jeff
