KX91-3 super series arm cylinder disassembly
HBuc
Kubota M5400, M8200, KX 91-3
Aug 3, 2020
Oliver
I have a hard time removing the piston from the cylinder shaft in order to replace the seals on the head. It almost looks like the (55mm or 2 3/16") nut is part of the piston or threaded into the piston. I have removed the set screw and the little ball below it and I have tried a few approaches, including using a sledge hammer, but I am worried that I could do some damage to the shaft, even though, this being an excavator, the shaft seems pretty solid. Any advice?
Thanks,
Hans
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,233
1,120
Amsterdam, NY
If this is the cylinder your referring to it should come off once you remove the set screw and ball.
whitetiger
Nov 20, 2011
3,795
2,198
Kansas City, KS
Here are the official disassembly instructions from the WSM.
