KX033-4 intake pulse
GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
Nov 17, 2014
316
137
Jefferson, Ohio
I get positive pressure pulses on the intake.
I think I should check the compression, leakdown and valve clearance.
Video link
KX033
11,021
Before you jump into a tear down, remove this pipe and see what you get.
Then check valves next.
Compression test will be good to have, just so you know what cylinder has the issue.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
Good idea.
I plugged that. Then I set the oil full cap on just enough to seal. It stayed put.
Also if I hold my finger on 020 there is no pressure.
I had to order the compression tester.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
The compression is 475 460 and 470.
The valve clearance good. .006 is real loose. It is less than. .010.
#40Fan
616
444
With the valve cover off, bar/turn the engine over and make sure all of the valves (especially exhaust) are opening the same amount.
11,021
.006 is too tight, .007 to .008 is the right setting.
Has anyone worked on this engine recently?
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
It is back together. I think I would have to pull the engine to look at the exhaust valves.
11,021
No, with the valve cover off you can see the valves moving.
Take off the pipe going from the intake to the air cleaner and see if you get that same back puff at an idle.
Have you replace both air filters (120 + 110) ?
Have you checked the incoming pipe (150) for blockage?
I've also see hoses collapse and cause issues.
GBJeffOH
Nov 17, 2014
316
137
Jefferson, Ohio
With the pipe off it is normal. With 070 off the air filter stays in place. I bought new spring clips (100). The cap is a lot tighter now.
I did crank it with the cover off. The valves look normal to me.
New filters did not change anything.
I think it is normal.
