Kx033-4 final drive oil drain plugs
MoCo
L6060 Tractor, SVL65 CTL, KX033-4 Excavator
Feb 15, 2021
40
Ontario Canada
The reason for not using an impact wrench is the hammering. The breaker bar exerts a steady push, and with a proper 8mm hex socket, fully inserted, will work. It will not be required after the first removal. The caps have a rubber o-ring under the head, so do not use heat.
Fortunately for me, what was stripped what mostly my Allen key, so a good socket, tapped in, worked to remove the stubborn plug. Doesn't have to be Snap On.
5,132
Common man.- that should be pretty obvious. What I was trying to say was counterclockwise (out) only - not back and forth.
Sorry......but "never in reverse" ......meant "never in reverse" to me!
LH thread?
The Evil Twin
L2501, LA526,
Jul 19, 2022
3,097
3,344
LH thread?
I think what he is alluding to is the "trick" to removing stubborn fasteners. It often helps to drive a fastener tighter and then loosen to break one free.
kubotafreak
Sep 20, 2018
1,049
395
Arkansas, US
50 years as a mechanic and I‘m not ashamed to say way less than 1% of my hand tools came out of a truck…. only because of the $$$$$$$. Really didn’t sound like the op has access to a tool truck.
Agreed, most of mine are craftsman. If I only got 1% of snap on though, it would be the gold zinc tipped allen/torx sets. I have broken countless 10 mm allen heads but never since I switched to the snap on set.
Semo
KX 033-4 Exmark EFI 60"
Apr 3, 2022
35
S.E. Louisiana
Upon closer inspection, the plugs are pretty clean with no corrosion, so I probably wouldn't have put any heat to them. Good to know there are rubber o-rings though. Will go to H. Depot ( less than a mile away) and get the hex socket. Thanks
Rover125
Kx040
May 12, 2025
Hazleton PA
I read all of the threads on removing the final drive plugs. Why are they so tight from the factory? Stripped the plugs. Can anyone offer advice on how to remove them? Thought about welding a bolt in the hex hole but don’t know if the heat would cause internal damage. Anyone have experience getting them out after they are stopped?
