Kubota Z725 turns over but does not crank
Tomhamma70
Z725 Zero turn mower
Mar 31, 2024
Canton, Mississippi
I have a Kubota Z725 Zero turn that will turn over but will not crank. This mower was bought new last year and only used for one mowing season.
4,245
Seat switch?
Mower engaged?
Bad battery connections?
Bad battery?
Bad starter?
Moose7060
M7060, Farm King PT740, HLA 2500 Snowpusher, LandPride RCR1872, Defender HD9 XT
Oct 14, 2023
150
335
bc
When was it last running? Has the fuel gone bad sitting too long?
2,191
Now not to be a tailhole - but crank and turn over are synonymous with each other. To turn over IS the cranking.
Your problem is no "fire" on that gas engine.
DID you use non-ethanol gas?
Did you pull the plug to see if it is wet?
Did you run it dry when put up at the end of summer last year?
whitetiger
Nov 20, 2011
2,606
1,117
Kansas City, KS
"Will turn over but will not crank"
Are you saying you can turn it over by hand, but the started will not spin it?
Is the starter turning the engine over (which is cranking) and the engine will not start/run?
