Kubota z724 zero turn
Rogerc
Jun 10, 2026
NC
Hello folks, I’m new to the forum but I have this mower and I can start it and when I take my foot off the brake pedal pedal the engines cuts off, I spoke to my dealer about this and they suggested it could be either the seat switch or the brake switch so I installed new switches and it still cuts off when I take my foot off the brake pedal.
Caden
1979 B7100
Apr 16, 2026
281
150
What about the switch(s) the that receive when the steering handles are in the neutral position?
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
122
67
Yankee occupied territory
With it running, brake set and the seat occupied pull one arm out. The engine should die. Repeat for the other arm. Engine should die. You’re testing for a faulty HST switch. If it stays running troubleshoot the faulty side.
The 50 hour start/opc test in the OM is a good troubleshooting check.
whitetiger
Nov 20, 2011
3,738
2,153
Kansas City, KS
If the engine will crank, the control lever safety switches are good as they only have 2 wires to them.
whitetiger
Nov 20, 2011
3,738
2,153
Kansas City, KS
We find a failed relay far more often than any switch.
Lug66
LX2610HSDC, Z422KWT
Jun 7, 2023
122
67
That’s only true if the seat is occupied, brake on, both levers in neutral and PTO is off. Starting isn’t the issue, keeping it running is. Pulling out either lever with the brake on will kill the running engine.
whitetiger
Nov 20, 2011
3,738
2,153
Kansas City, KS
I am very familiar with the operation and repair of these mowers, plus I have the WSM right here in front of me through the Kubota dealer portal.
Go ahead and instruct people to perform a bunch of useless checks.
Just make sure you tell the person what you are doing first.
Rogerc
Jun 10, 2026
NC
Thanks for your response, so I did like you said on both sides and each time the mower cuts off.
whitetiger
Nov 20, 2011
3,738
2,153
Kansas City, KS
Yes, I know your steer control lever safety switches are working, as the engine will crank.
Is your model number Z724XKW or Z724KH?
Is your serial number below 50001 or above?
There are at least 4 different wiring schematics for a 724 mower, and each is different.
Rogerc
Jun 10, 2026
NC
Serial number is 12437
whitetiger
Nov 20, 2011
3,738
2,153
Kansas City, KS
Here are the wiring schematics.
Have you checked the relays?
Screenshot (149).png Screenshot (150).png Screenshot (151).png Screenshot (152).png Screenshot (153).png
Rogerc
Jun 10, 2026
NC
Yes and found the seat relay was bad, replaced it and working now.
Thanks to all your replies to this forum, I appreciate your help.
