kubota tiller questions
les525
21
ca
i came across a kubota 3pt tiller for sale to use for my b7100. i think its a fs1020?? what exacly is it? is it a grey market? are they any good? how wide are they? parts? there asking 750 for it. i will be dealing with a lot of compacted soil. please give me any opinions.
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
I believe you will find that the FS1020 is a 1020mm wide tiller(apx 40.2 inches) From what I can see it appears to have a slip clutch which is a good thing, One of the important things is to make sure it turns in the proper direction for your tractor so you will have to determine the rotation direction of your tractors PTO and then turn the tiller in the same direction to see if it turns correctly for you, You may want to check the gear box to see how the oil looks and has not obvious signs of water or metal fragments,and the chain drive on the drive end should be checked to see what condition the chain and sprockets are in. I would also check all the tiller tines and the main shaft to make sure there is not any excessive wear, A check over of the housing for rust or breaks that will need to be repaired.
Just from what I can see in the pics it appears to be missing some tiller tines
Does the price include the goat?
les525
21
ca
no, goat not included. i would not want it if it was free.
i have not seen it in person yet. i was told it was in good condition then i got these pics afterwards. it looks like its been sitting in the elements for a while and i did notice tines missing and the ones that are there look like they have some wear.
is the fs simalar to the fr? i have found parts for the fr but not the fs. i will have to check the rotation on it. 750 to mee seems too high for a tiller that at least needs tines if they will be easy to find
