I Ike New member Equipment Kubota L 3301, Farmall Cub. JD B. Ferguson TE 20 Jul 18, 2015 324 1 0 Mich May 8, 2018 #21 red347lx said: No it won't spin by hand Sent from my SM-G950U using Tapatalk Click to expand... Carefully put channel locks on it and try turning the shaft on the gear box. The tiller has to be up and then see if it turns
R red347lx New member May 6, 2018 12 0 0 US May 8, 2018 #22 Here is a problem..not sure where it's from or what I need to replace Sent from my SM-G950U using Tapatalk
R red347lx New member May 6, 2018 12 0 0 US May 8, 2018 #23 As you can tell, it's been very well maintained ***129322; Sent from my SM-G950U using Tapatalk
D D2Cat Well-known member Lifetime Member Equipment L305DT, B7100HST, TG1860, TG1860D, L4240 Mar 27, 2014 13,708 5,373 113 40 miles south of Kansas City May 8, 2018 #24 Looks like you need to start cleaning parts. You have a bearing that has given up the ghost.
North Idaho Wolfman Moderator Staff member Lifetime Member Equipment L3450DT-GST, Woods FEL, B7100 HSD, FEL, 60" SB, 743 Bobcat with V2203, and more Jun 9, 2013 29,861 6,070 113 Sandpoint, ID May 8, 2018 #25 Pull the snap ring off and the gear and you'll see where the parts used to be located!
R red347lx New member May 6, 2018 12 0 0 US May 10, 2018 #26 North Idaho Wolfman said: Pull the snap ring off and the gear and you'll see where the parts used to be located! Click to expand... You sir were 100% correct. The bearing behind the gear that drives the chain exploded...in for repair now! Thanks for all the replies and I sight everyone. It is greatly appreciated. Sent from my SM-G950U using Tapatalk
