Kubota RTV excessive shaking
kubota.ray76
57
round rock
My RTV X900 vibrates really rough when it idling but stop when I increase the rpm’s slightly? What the cause and what to do to fix it?
Any comments, suggestions, or recommendations would greatly be appreciated.
Thanks
3,326
Increase the idle setting!
I had to do this also. Some people are obsessed with slow idle speeds on engines and diesels DONT LIKE IT!
Raise the bed (and set the safety-strut) and have someone press the “accelerator” pedal and you’ll notice that the idle control lever (right-side, front of engine) has a hex-head bolt that is safety-wired. That is your idle adjustment.
INcrease the idle speed until it smooths out.
This will not affect your RTV movement from standstill. The “accelerator” pedal actually controls the VHT (transmission) speed, and the engine will accelerate in symphony with increased vehicle speed.
I had to do the same thing and the little RTV has performed flawlessly since.
lugbolt
ZG127S-54
Oct 15, 2015
5,248
1,927
Mid, South, USA
it might have other problem than just "idle too slow". They didn't vibrate much from the factory so why is it now? Gov spring? Starving for fuel? Low compression? Poor or contaminated fuel? Failing nozzle or injector pump? Stuck valve in the pump? Fuel shutoff solenoid sticking?
Saxman
L3830 ZD21
Jun 19, 2010
154
Mt. Vernon, IL
I installed the hand throttle kit on my X1120. You can set the idle up while stopped or if you want maximum power while pulling something heavy you can set the engine to half or three quarters throttle and it acts just like a hydro tractor. The “accelerator” pedal will just control the transmission. The kit is over $100 but is high quality and is easy to install.
