bx tractorjoe
The other day I pulled the mower off my new to me bx2200 to replace the blades and check the bearings and gear case..
Come to find the gear case had no gear oil.. being I had no parts, and wanted to see what the problem was I filled it with 80w90 and stuck the deck back on..
Went to mow today and about 10 minutes in smelled gear case oil.. sure enough it was leaking..
I suspect the bottom gear case seal is toast as there was a good puddle under it.. going to pull it apart tomorrow and see whats going on..
should say going to attempt to.. never pulled one of these apart and could use some advice mostly on getting it off the deck, attempted to yesterday and it seemed to be struck to the shaft going to the middle blade..
I have some nice pully pullers so should not be to much of a issue, just looking for some pointers if anyone has done so before
