kubota m5-111 cranks but no start
bmbfarm03
m5-111
Aug 6, 2022
batesville, AR 72501
fuel is getting to the supply pump but little to none going to rail it all seems to keep going back threw the return line. also you can keep the key on for 20 min or more and the pump never stops the pressure is never building up in the rail.
5,246
1,923
rail pressure sensor bad? Maybe fuel injector(s) leaking internally?
Really need diagmaster to diagnose these, not really any other good way to do it other than start replacing part$$.
TECH101
Kubota - Bobcat - Caterpillar - Case - John Deere - FARM - CONSTRUCTION -
Mar 8, 2022
69
15
Year / hours ?
TECH101
Mar 8, 2022
69
15
When the key is in the ON position your electric fuel pump also known as (Supply Pump - Low Pressure Pump) will not turn off and is normal operation.
Because its a low pressure that feeds your high pressure (Injection Pump) .......... There will never be any high pressure at the rail
Your high pressure pump (Injection pump) is mechanical - meaning if the engine is not cranking no high pressure can be produced
Give me your story
when was it running last - when did the problem occur ?
Barfour
Kubota M 7040
Aug 8, 2022
Sour lake tx
Got a m7040 governor spring was knock off while mowing. Had a runaway brewing so bogged her down in heavy heavy grass. Now it will not start. It acts like it trying to start but never does. Put a electric pump around the mechanical lo pressure pump. No difference. Took tube off #1 cylinder not much if any fuel flowing. Getting good flow to the injection pump. But not much if any out. Is there solenoid valve on injection pump that can be stuck closed?
