I have an m 4800 with the straight gear transmission. i was working with it today and it just stopped going into low forward or reverse. high forward still works but that operates on a separate linkage. looking at schematics, the most likely failure inside the housing is the shift lever spring that connects the two shift levers. Does anyone have experience/ advice on this problem? It looks to me like the rearend has to be taken off to get to this area. i took the access plate off under the 4 gear shifter and you cannot access it from there. If thats the case, what kind of labor prices am I looking at. Is it something I can handle doing myself. Thanks in advance.
_ -Jordan
_ -Jordan
