I am considering adding a "limb ninja" rotary cutter to the front loader. I have a set of unused remotes on the rear. The cutter requires a case drain. Anybody ever had to do this on one of these? Recommended tie in location? Recommended kit?
The cooler lines are rubber lines, so they are super easy to tap into.ouch this is not as easy as I thought. Perhaps a filler cap with a threaded hole in the center? NIW do you know of a specific location I can find a port to return to the sump? Each one that I have found so far has a valve inside it. I like the idea of cutting into the cooler lines, but then again I really don't like the idea of hacksawing a line and sliding rubber hose over it to repair it. Would love to plumb into the rear remotes as normal and then disconnect the return and plug it straight into the fill hole when needed.....
