Kubota L5030 leaking oil from behind front axle case
Mikesushchyk
Kubota L5030 2004
Aug 22, 2025
Massachusetts
Hi,
I have a Kubota L5030 leaking oil from right behind the front axle case. The front pinion/bevel gear area if I've done my research correctly. Is it just a seal that needs to be replaced? How involved is that repair?
Thanks
pigdoc
G1800S L2500
Aug 19, 2022
336
271
SE Pennsylvania
How bad is the leak?
Doesn't look very bad from the pic.
If so, I wouldn't worry about it.....until the leak stops (axle out of oil).
Seriously, time to get some data to determine how bad the leak is.
I could have changed the front pinion seal on my L2500 when I replaced the driveshaft.
It's an all-day job.
-Paul
Mikesushchyk
Kubota L5030 2004
Aug 22, 2025
Massachusetts
The leak is definitely pretty good once I shut the tractor down it leaks (dripping slowly) about 20-30 drips. That's probably a terrible way of quantifying the leak but the picture doesn't really do it justice. I wanted to post a video but the file is too big.
