Boy, I am sure glad that my tractors do not have an ecu. Good luck and thank you for the updates.
After over a month of my 2019 Kubota L3901HST being in the shop we now learn it was a bad (or just stuck) suction control valve problem. Not covered under my warranties. My wallet says OUCH! My service manager says he has only seen this on the larger Kubotas. Unknown cause but he did recommend that I use red diesel in the future rather than from a gas station. I think you have to have an ag exemption for buying the untaxed diesel though?UPDATE: My problem still persists after fuel rail was changed out. One should note that only two codes were showing on the dashboard when the tractor was taken to the shop, e.g., P0087 and P2294 but 3 codes were found to be stored. Kubota shop manager now thinks it may be a problem with the ECU (one of the two onboard controllers?) due to known problems with it on this particular tractor.
I will update here whenever the problem is resolved.
The old Fords just never die.Will do Dan. With all this rain recently, I guess I'm lucky to have my old trusty 1951 Ford 8n that I can use to keep the weeds knocked down.
The only difference between "red diesel", and diesel for highway use, is the coloring dye!After over a month of my 2019 Kubota L3901HST being in the shop we now learn it was a bad (or just stuck) suction control valve problem. Not covered under my warranties. My wallet says OUCH! My service manager says he has only seen this on the larger Kubotas. Unknown cause but he did recommend that I use red diesel in the future rather than from a gas station. I think you have to have an ag exemption for buying the untaxed diesel though?
Please note that I cannot complain about the time it took for the repairs because I had told the shop the tractor was more of a toy than a tool and that there was no hurry but I'm sure glad I had my trusty old '51 Ford 8n with a shredder as a backup. I would be neck deep in weeds.
So they were guessing what it was by firing the parts cannon. $1600 fuel rail that did not need to be replaced. Hopefully big k ate that expense. But more often the consumer get screwed while the dealer guesses at someone else’s expense (and to their profit). No better than car part swappers.After over a month of my 2019 Kubota L3901HST being in the shop we now learn it was a bad (or just stuck) suction control valve problem. Not covered under my warranties. My wallet says OUCH! My service manager says he has only seen this on the larger Kubotas. Unknown cause but he did recommend that I use red diesel in the future rather than from a gas station. I think you have to have an ag exemption for buying the untaxed diesel though?
Don't think he was suggesting that. I think he was just suggesting buying diesel from place who sells a lot of it and not our convenience store in a town of only 1200 folks who mostly drive gas rigs. The only other place close to me that sells a lot of diesel is our Coop.The only difference between "red diesel", and diesel for highway use, is the coloring dye!
The service manager is suggesting to you that the color of diesel can affect engine operation?
My take on this: You should look for a dealership with a more knowledgeable service manager.
Yes Kubota did cover everything but the suction control valve R&R. However, it's still a significant bill.So they were guessing what it was by firing the parts cannon. $1600 fuel rail that did not need to be replaced. Hopefully big k ate that expense. But more often the consumer get screwed while the dealer guesses at someone else’s expense (and to their profit). No better than car part swappers.
Ha! I barely get telephone service out here in the "boondocks" of the Texas South Plains. The only persons who seem to know I'm out here is my post lady and the county tax appraiser. And with our unpaved road, I think the post lady would like to forget about me on bad weather days.The only difference between "red diesel", and diesel for highway use, is the coloring dye!
Yep. Great old tractors the n-series were. Although I prefer the late 1950 to 1952 8Ns with the side distributor, I have owned over 40 of these guys (9ns, 2ns, 8ns) since retirement almost 25 years ago. I use to buy and sell them but age and the lack of patience has finally caught up to me.The old Fords just never die.
I have owned mine (1951 also) for 50 years.
MORE UPDATE: After actually picking up my Kubota, I was told they did find a rodent-chewed ground wire they had to repair. I do not know if the wire was completely chewed into or not.After over a month of my 2019 Kubota L3901HST being in the shop we now learn it was a bad (or just stuck) suction control valve problem. Not covered under my warranties. My wallet says OUCH! My service manager says he has only seen this on the larger Kubotas. Unknown cause but he did recommend that I use red diesel in the future rather than from a gas station. I think you have to have an ag exemption for buying the untaxed diesel though?
They are covered in the event of their failure, but Kubota is rather finicky about replacing a part someone THINKS has failed. If Kubota calls for the rail, tests it, and deems it OK, the dealer will get charged back for the part and labor as they should. The rail is very simple to monitor using Diagmaster as is the SCV.Difficulty getting corporate approval is one thing but coverage of fuel delivery and injection components is clearly enumerated in the emissions warranty.
yup a lot of times owners think that dealers are the warranty administrators, that the dealer eats the cost. Nothing could be further from the truthThey are covered in the event of their failure, but Kubota is rather finicky about replacing a part someone THINKS has failed. If Kubota calls for the rail, tests it, and deems it OK, the dealer will get charged back for the part and labor as they should. The rail is very simple to monitor using Diagmaster as is the SCV.
There are also a few very simple and quick tests using a multimeter in conjunction with Diagmaster that would have confirmed the fuel rail sensor operation.
