I am working on my aunts L3650 kubota. We just put a new clutch disc in it. While we where putting it back together I cross threaded the high pressure hydraulic feed line for the steering. I tried to rethread it on but I had cross threaded it to bad and now the hydraulic fluid just pours out. It looks like there is just a valve body for the steering. The high pressure feed. a low pressure return and what i would guess are the lines that send fluid out to make it turn right and left. Can this valve body be replaced or is it possible to just replace the stripped fitting? Unfortunately we dont have a shop manual on it so i am just going off my own experience. If i have to replace it does anyone know if there is an interchange with other models? It is the 4x4 model with a dry clutch. In need of help. Thanks
