Kubota L35 big mistake on hydraulic loader valve looking for advice.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
That cant be right. Without a inlet relief on the loader valve people could/would fry the pump in everyday loader use.
The L35 is a plumber's nightmare. The fluid goes from the front pump back to the relief on the 3ph, then back up to the loader.
5,861
I was pretty sure of that. Kubota did and still does use that routing on a lot of machines. I looked the L35 schematics over about a year ago and its an "interesting" design. Lots of levers to keep organized 🙄
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
I assumex the blocked neutral just blew every thing on the bottom out. But if the bucket spool is shifted to "slow extend" the blocked tank core will see roghly 1.5 times inlet pressure so jaybe tgats what happened. What is tractor side relief set to and whats the rated max on the valve?
The relief is set at 2489 to 2560 psi and the valve is rated at 3000. I don't see a spec on the tank passage. I didn't think about the multiplication effect.
5,861
The tank port limit is going to be 500/600 PSI but thats not a burst pressure. The old grey iron in those valves is probably getting tired and this was a straw too much...
EDIT
5,861
BTW - you may not have considered the multiplication factor but you picked up on it immediatly. I also didnt think it completely through Since the boom is a serial circuit commanding lift at the same time as commanding dump multiplies pressure twice :
2500 PSI x 1.5 x 1.5 = 5625 PSJ
Youser!!
Fluke216
l35 kubota
May 2, 2021
84
21
PA
The L35 only hits a relief valve on that circuit if the BH is in place or the spool on the outlet is turned.
Yes it's a bad design in the way they made the relief at the end of the loop.
I believe it's done this way because that BH does not have a PB like newer valves, but I'm not sure.
OK, it looks like the tank passage (low pressure) is the one that blew out. @Fluke216, make sure the tank hose is connected correctly and not plugged. @TheOldHokie, do you see any other way this might be over pressured?
I went and got the Valve, the whole setup. Left before 2 got back after 10. I also got the pressure relief valve that was on that machine it looks better than mine. Should I have it tested or test it following the wsm. Thanks for all the information here much appreciated just wanted to clarify so I don’t screw something else up. The pressure relief valve didn’t work because I did not have the hoses connected? Additional info I had the boom raised and the bucket was fully dumped but wouldn’t roll back and I was obviously screwing with it more then I should have when it blew out.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
Did that valve come off an L35, or a different model?
I don't know of a way to test the relief valve except on the tractor. You could put a gauge on the pump hose at the valve, start the tractor briefly, and see what pressure develops.
MOST IMPORTANT Make sure you don't have the tank and power beyond hoses reversed. The tank hose port is toward the tractor front and goes to a port on the transmission housing, I think. The power beyond hose comes off the back of the valve and goes to the backhoe.
The tank passage, where your valve broke out, is designed for low pressure, 500 psi max. You can see the casting is relatively thin there. Obviously, it can withstand more, but if the hose is blocked, it could see around 5000 psi with the relief valve operating correctly.
This could have happened even with the relief valve operating properly. And the backhoe hoses should be connected together when the backhoe is removed to prevent deadheading the pump against the relief. But I don't think that would have broken your valve. The only way I can see this happening is that the tank connection was plugged somehow.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
yes the valve came off an L35. I’ll double checked that those weren’t reversed and they weren’t unless I made a mistake I thought they were different fitting like the PB has a strait fitting and hose had a 90 and the one to the rank had a 90 fitting and a strait on the hose. I’ll check that the hose one to the tank is not plugged somehow. I was doing more then I should have trying to roll the bucket back maybe it exerted a bunch of pressure quick somehow, or that’s how it seemed.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Does this make more sense if the tank and power beyond lines were reversed. Because I’m thinking that’s probably what happened the line from to the tank is clear.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Swutching PB and tank does not create a deadhead. Blocking them does.
Hmmm I think they were definitely switched and the ones to the backhoe were not plugged together. Does that create the dead head?
I hooked the new one up double check led it was all hooked up correctly seems to function fine boom goes up and bucket dumps and curls. Only check that quick then shut it off.
5,861
You have to understand things are inter-related
When the BH hoses are not looped together the PB circuit to the 3pt and from their back to tank is deadheaded. Thats the basic mistake and what happens as a result varies based on the upstream connections.
  1. If PB and T are NOT REVERSED the PB port in the loader valve is deadheaded and over pressurized at all times but T is not. Dump and curl will work fine but lift and lower will not
  2. If PB and T are REVERSED the PB port is NOT DEADHEADED . It simply dumps to tank and the 3pt will not work. The tank port IS DEADHEADED but it will only be over pressurized when you try to curl the bucket
Fluke216
l35 kubota
May 2, 2021
84
21
PA
Thank for that detailed response I was still a little confused as some conversation between you guys about what created the actual dead head. I created it by not plugging the lines together that were removed from the backhoe. The method of how it happened was one way or the other but is evident that it was #2 the tank port is dead headed and I was trying to curl the bucket. Dumb mistake on my part I think I was fortunate to locate that assembly on a tractor being parted out. Very much appreciated to everyone that gave information on my situation.
One side question a section of the parallel link is missing on this tractor should I make something to go in its place as it seems to be a discontinued part.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
Yes, those quick disconnect couplings have spring loaded balls or poppets that stop the flow when decoupled. So, with the hoses reversed, when you left the hose uncoupled the tank port was effectively plugged.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
The purpose of that linkage is to prevent dumping a load out the back of the bucket if the operator neglects to roll the bucket forward as he/she booms up. There have been cases of injury and damage from this. Would the seller of your valve have one to sell?
Fluke216
l35 kubota
May 2, 2021
84
21
PA
I tried to get it but he wanted to keep it on the loader for some reason. I could have him measure it and probably make something out of threaded rod and some modified pieces on the ends.
Fluke216
l35 kubota
May 2, 2021
84
21
PA
OkI see makes sense thanks for that explanation and all the responses. I don’t know why I didn’t think about it I guess the machine was completely dead when I took the backhoe off and didn’t think about plugging them together
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,492
2,073
WestTn/NoMs
Do you have an owners manual? You need to make sure you have the directional valve set properly or you could have the same situation on the backhoe valve if the 3ph hits top limit and is adjusted a little off.
L35
Jun 13, 2010
632
660
CT
That rod is nothing special. You can probably make one out of 1/2” emt conduit and smash the ends flat in a vice then drill 2 holes in each end. I’ll attach some pics for reference and current length. (45” center to center)
