R Randy2 New member Feb 28, 2021 1 0 1 USA Feb 28, 2021 #1 Instrument cluster flashing ops po336 Last edited: Feb 28, 2021
freewheel3 Active member Equipment MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211 Mar 9, 2013 333 34 28 Alberta Feb 28, 2021 #2 Crank position abnormality. Sometimes caused when tractor is stalled. Your operators manual might tell you how to clear the code on the display, or your dealer might have to do it. (This is assuming that the tractor runs ok?)
L lugbolt Well-known member Equipment ZG127S-54 Oct 15, 2015 5,504 2,211 113 Mid, South, USA Feb 28, 2021 #3 search the site for the code there are several writeups the search button is your friend you're welcome
