Kubota L305 oil in water
Jrsum73
Kubota L305
Feb 20, 2021
Mississippi
I have an older Kubota L305 around a 85 model. I changed the head gasket but I am still getting water in oil. I have no pressure at radiator cap and checked water pump it is working. The more water you pour in the fuller the oil becomes. Any suggestions
2,600
Did it ever overheat?
When you say no pressure at cap..... any bubbles while running with cap off?
Any smoke at all when running?
Jrsum73
Kubota L305
Feb 20, 2021
Mississippi
No bubbles at all. At start up has lots of white smoke for a minute or so then none unless I rev the motor then it's black
BruceP
G5200H
Aug 7, 2016
851
368
Richmond, Vermont, USA
When the head was off to replace gasket... was the head and block inspected for cracks?
You could try a 'leakdown' test.... replace radiator-cap with special cap to allow pumping pressure into system... if it bleeds-down, there is a problem somewhere.
Also, when cranking the engine (do not allow it to start), it is often audable if one of the cylinders does not have compression. There will be kinda 'skip' each time the weak hole tries to make compression.
You may end up pulling the head again... and IMMEDEATLY inspect for water in one of the holes.
Jrsum73
Kubota L305
Feb 20, 2021
Mississippi
Yes I had a friend use a ultrasound on it it was all good
kubotasam
Apr 26, 2010
1,206
129
Alfred Maine
When you say " The more water you pour in the fuller the oil becomes" Does it fill the crankcase with water without the engine running? If yes then I would suspect a core plug (freeze plug) rusted through. You may find one behind the timing gears on front of engine or under valve cover.
Jrsum73
Kubota L305
Feb 20, 2021
Mississippi
Yes that was my suspicion after head gasket. I checked ones on top of head but they were good from what I have been reading there is freeze plugs behind crank Case I now suspect it is one of them
rbargeron
Jul 6, 2015
1,172
239
western ma
There's another sealing plug inside the front engine cover - part 5 on this parts page - (L345 and L305 have same plug)
6,935
Um which is it?
Oil in the water?
or
Water in the oil
You state both????
There is a huge difference!
